bumps with lowered altitude!! (lots of great custom bumps!!)
elgemcdlf
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Post by elgemcdlf »
Dr Casti wrote:First of all what to thank you all of you for your replies, specially Bobby.
This is what i did so far on my 68 F-250 CS:
- took off two leaf springs on the rear
- flip out the front bracket on the rear springs.
Now i got between 4 and 5 inches lower. Probably need to compensate for pinion angle, but need to finish lowering the front.
Probably i'm gonna need some drop shocks, or relocate the upper base for the shock absorbers...don't know yet.
For the front suspension, i'm gonna cut one or one and half rounds on each front spring and see what happens.
The ideal angle for shocks is 30 degrees. Keep that in mind when you are making your decision. You should have measured your pinion angle prior to lowering the rear. Lowering the front will not change the pinion angle in relation to the trans which is what you are looking at.
Dr Casti
Post by Dr Casti »
Here's the progress so far...
Front: Cut one round on each spring. It lowered 1 inch aproximate, so From 17 inches originally to 16 now.
Rear: Took off two leaf springs and flip over the front bracket. It lowered 5 inches aprox. From 19 inches to 14 now.
There's two inches difference between the front and the rear, but i can always put back the leaf springs that i took previously to correct for pinion angle.
So far i like it. :)
1969 Ford F-250 Camper Special. 360 V8, C-4 auto.
Joshpow
Post by Joshpow »
For real this time!! I cut 1.5 coils front off 460 springs when I did the 77 disc swap. In the rear I flipped the spring perch and rebolted with 2 closest together bolts and drilled 2 more!! Measures 1.5 taller at the center of the bump in the rear.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
ezernut9mm
Post by ezernut9mm »
Joshpow wrote:For real this time!! I cut 1.5 coils front off 460 springs when I did the 77 disc swap. In the rear I flipped the spring perch and rebolted with 2 closest together bolts and drilled 2 more!! Measures 1.5 taller at the center of the bump in the rear.
nice. :D
SoCalExile
Post by SoCalExile »
Nice.
What size rims & tires?
Joshpow
Post by Joshpow »
15x10 rear with 265/70-15s and 15x7 front with 235/70-15s. all got std backspace.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
XXXWEBERXXX
Post by XXXWEBERXXX »
SoCalExile
XXXWEBERXXX wrote:[ Image ]
The mini-spear on the side, how did they do that? Is it paint, cut down trim, an aftermarket item, something else?
XXXWEBERXXX
Idk but I like it. The cut down bumpers, shaved drip rails. All sweet!
Kraig
Post by Kraig »
n the article it says the guy made the trim from stainless angle...it looks good!
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
shoots
Post by shoots »
Here is a pic of my work in progress.
1972 Sport Custom 400/FMX
BobbyFord
Post by BobbyFord »
shoots wrote:Here is a pic of my work in progress.
:D I like it. What's in it?
shoots
Post by shoots »
I rebuilt the 400 the previous owner had swapped for the original 302.
BobbyFord
Post by BobbyFord »
Nice. Looks real good :thup:
fixxer
Post by fixxer »
What did you use to lower? and plans for the rear?
