Blueford wrote:My new ride,360/4spd, gonna be 460/4spd here soon , 35s,4.10s,4spd,not going any higher but am gonna get the body all straightened out("custom" body lift on there thats gotta go) ordered new poly body bushings for it and we'll see how it sits with the new bushings to see if the body lift is even needed to clear the 35s. Anyways, here it is:
Is that a period correct blue? I know they offered a darker blue color in the late sixties for other model vehicles but wasn't aware they actually offered it for the F100. If it isn't I would still be interested in what kind of blue that is. I was also curious how much of a lift that was, it appears to be 6"+ but sometimes photos can be deceiving.
hazelnut wrote:Ive got a 69 highboy too. Not ready to be back on the road yet but ive got 35x14.5s on it and need to put a leveling kit on it give me the clearance needed for 35s. mine got the stock suspension under it and has a 3" rake to it. go to the project updates and check out WTCfireguy truck, he put a leveling kit on his 70 and is running 35s.
With good front springs or a disc brake front end it will fit 35" 12"s just fine. Otherwise you get just slight rubbing on the steering arm at full lock turning to the right.
With a leveling kit and good rear springs with some minor trimming you should be able to run 37s.
When I get home i'll try and throw up some pictures of mine on 35s.
I know its not a ford but here is my toy. 22R motor 3" lift with 35's it has a header and a webber 2bbl carb and 2.5 exhaust and whats called a side shift 4speed just means the shifter is bolted to the side instead of through the top of the trans. I call it my Billy Goat it wasnt on there in this pic but i have a hood ornament from a late 30's to early 40's dodge truck its a big ram head .
Foggy
you may have to make one as a lot of companies quit making stuff for the older trucks. It's the old supply and demand thing ya know. The bumpers i have are home made and i know a lot stronger than any you could ever buy for it. but you might try marlin crawler. Here is a link to the forums but you can find links to supplyer's there also. http://board.marlincrawler.com/index.php
Don´t know if this has been posted here before, also not really 4x4 pictures, but awesome movies of off road action in Alaska. Many Dents and also some Bumps involved
Heres a couple of my on goin project of a 72. Gonna lift it a couple inches and some bigger tires with a possible gear swap to taller gears before we tear it apart for tons of body work. Its got a 410 that me and my dad are still messin with, other than that its bone stock. Been a farm truck its whole life till I got it.
Before I got the brush guard, stock bumper, spot mirrors and tool box.
