no brake lights or emergency flashers
- Kurt Combs
I have had a problem with my turn signal for turning right. Most of the time it does not work, but sometimes it does. The left works just fine. I just took the steering wheel off again to check out the turn signal switch. By pushing the wires around and adjusting the hold down screen I got the right turn signal to work most of the time. The previous owner had someone install a later model switch and he cut some wires and spliced them to make it work with the 1972 column wiring. The splices go through the small hole in the steering wheel very tightly. I probably need a new switch. But to make matters worse, I have no stop lights and emergency flashers. When I pull the emergency flasher on, the front lights come on, but not the back. Seems like all these problems are interrelated.
What do you guys think?????? I would really like to get the brake lights working to I can drive my truck to work 30miles. Any help would be really appreciated
Thanks in advance, Kurt Combs
Kurt
1972 F-250
1972 F-250
- FORDification
- Site & Forum Admin
re: no brake lights or emergency flashers
All the lights run through the turn signal switch, and since you've determined that yours has been jury-rigged and is malfunctioning, replacing it should be the first course of action. I'd be willing to bet your lights will function properly with a new switch in there.
- Kurt Combs
Keith,
Thanks for the response. I thought there might be somewhere else that just the brake lights and emergency flashers ran through. I was hoping for a quick fix so I could drive the truck to work on Monday. I will get that switch ordered and see what that does for my problems.
Thanks again.
Kurt
Thanks again.
Kurt
Kurt
1972 F-250
1972 F-250
- adrianspeeder
Yup, need to get the right switch in there correctly wired. Facing similar electrical butch jobs on the 66.
Adrianspeeder
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- flyboy2610
Problems with the turn, brake, and emergency lights seem to be very common on these trucks, and many times it turns out to be the turn signal switch.
Red Green
you'd better be right.
Red Green
- Kurt Combs
Thanks to all who posted and told me to change the turn signal switch. Turn signal switch installed and problem is solved. I should have gone for the more expensive brand as the switch was not identical to mine. I had to cut part of it off and figure out the wire colors to make it work. Looked like it was for a later truck. It sure is cool to have brake lights and turn signal that work.
Kurt
Kurt
Kurt
1972 F-250
1972 F-250
- flyboy2610
Glad you got it working!
Red Green
Red Green
- flyboy2610
You can get them from LMC Truck, Dennis Carpenter, Or National parts Depot.
http://www.lmctruck.com/
http://www.dennis-carpenter.com/
http://www.npdlink.com/
They will run you about $60.
Red Green
Red Green
thanks flyboy!!
- flyboy2610
And you get what you pay for.
Red Green
Red Green
