Manual to Automatic Hubs
4x4 & Off-road Forum Archives
Moderator: Doug Comer
Ripsnorter
Postby Ripsnorter » Tue Jun 03, 2008 2:02 pm
I know I know, 90% of the people out there are converting FROM auto to manual hubs.
I however do very little 4x4'in, but when I do it'd be nice to have auto hubs instead of having to get out and lock them in.
Does anyone know whats out there as far as good, solid, durable auto hubs? Anyone tried them?
Rockcrusher
re: Manual to Automatic Hubs
Postby Rockcrusher » Tue Jun 03, 2008 7:30 pm
Auto hubs are OK if you're in an intermittent situation where you need 4WD. Generally, because of their design, they won't handle as much torque as manual hubs.
I ran them on a couple of my rigs in the past, a '65 F250 4X4 and a '79 CJ5. No problems except for one time on the Rubicon in the CJ . . . Low gear/Low case on granite was a bit much.
Are they even available anymore?
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
averagef250
Postby averagef250 » Wed Jun 04, 2008 11:46 am
You can run the stock 80's/90's Ford auto hubs if you have either the weeny 1/2 ton hubs or the internal 50/60 hubs.
Return to “Archives”
Who is online
Users browsing this forum: No registered users
