Anyone know the reason for this bar? was it a factory option? part of a HD upgrade package? i only see this stabilizer bar on about 2 out of every 10 highboys i come across, i assume it's fuction is to help eliminate any possible drivetrain chatter and provide extra stability to the T-case but if so why is'nt it on every highboy?
T-case stabilizer bar
Moderator: Doug Comer
Jim
'75 Ford Highboy 390 4spd
- Wes
the np 205's came w/ the bar the D24 did not but it makes for less t case movement under heavy loads.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
