390
390
I need a cost efficient way to convert my 2bbrl carb and intake, to fuel injection. She's a 1972 highboy with a 390 and low geared. I'm currently looking for a trans mod, to achieve better towing speeds and I need to get efficient gas mileage while I'm at it. Any suggestions??
Re: 390
Hi,
Well.... trying to achieve efficient gas mileage with these Highboy's is like trying to mix oil and water.
There are fuel injection kits out there but their hi-cost usually negates the purchase.
There are also a few options concerning the trans/gearing.... but again they aren't cheap.
Going to taller tires will lower RPM's at highway speeds but doesn't help with towing.
For the trans,... I went with a Ranger Torque Splitter overdrive .
Gear Vendors makes an overdrive unit. Or you could put an NV4500 5-speed, or ZF unit. Again, all of these options are $$$ and not for the faint of heart to install.
Lee
Lee
Re: 390
Lee, with the 27% reduction on the final drive what did that end up translating to in additional MPH.
I have a 71 F250 4x4 with the 390 and 435 and it comfortably drives about 60 before it sounds like I am wringing it's neck. I would be happy with 70 if I could get it.
I have been pondering all the other suggestions you mentioned too.
Brent
Brent
1971 F250 Explorer 4wd
2006 E350 Adventure Van 4wd
- colnago
Re: 390
If you want decent mileage, my vote is to pull the 390 out, and swap in a 351. Sorry, not what you wanted to hear. I love my 352, but the FE is not an efficient design.
Joseph
Joseph
Re: 390
Well you didn’t define “cost efficient” but there is this:
https://www.holley.com/products/fuel_sy ... el_system/
Re: 390
Hi Brent,Socal F250 wrote:Lee, with the 27% reduction on the final drive what did that end up translating to in additional MPH.
Brent
To be honest I have never checked the fuel mileage on the truck.
Running tall 36" tires and having the over-drive makes highway driving comfortable.... RPM wise.
I installed the Over-drive due to the fact that I pull a heavy Travel Trailer regularly over a 6000 ft mountain pass. The ratio spread between 3rd and 4th gear is so large on the 435 that I can't maintain speed in 4th and downshifting to 3rd ran the RPM's uncomfortably high. With the OD I shift into 3rd OD and can maintain speed with comfortable RPM.
Lee
