- hfdco4
Question for all of you. How did you flip your cab onto it's back? I was thinking of using blocking in this area, see pic.
Then lifting the front with an Engine Crane or the Gantry Crane?You do not have the required permissions to view the files attached to this post.
FE390PC
FE390PC
- cdnwillyg
Paul, when I took my '55 cab off it only took two of us by hand and we flipped it on it's back, so I would think your cab should go that easy also. Maybe have three guys if you can! I should mention that we didn't have any glass in it or doors on.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- hfdco4
Thanks Willy, most of the time it's just the wife and I doing the work.
FE390PC
FE390PC
- hfdco4
So was looking for my spring pad again and ran across more parts to get rid of. The outers from a Dana 44HD Closed Knuckle axle.
FE390PC
FE390PC
- Manny
hfdco4 wrote:So was looking for my spring pad again and ran across more parts to get rid of. The outers from a Dana 44HD Closed Knuckle axle.
Hey wanna trade some parts??? I always love the big hub stuff, and spares are great!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- hfdco4
What do you need or want?
FE390PC
FE390PC
- hfdco4
Got back out to the garage today. Working on the floor patch first. Got the patch laid on top of the floor and marked for cutting. Have to put a few rivets in then I can cut.
FE390PC
FE390PC
Wow what a nice cab! You'll have that ready to go in no time!
Kyle
Kyle
- Manny
Hey Paul glad your getting some of the patches done, and the wife didn't kill you for being gone valentines. The hubs just let me know what you need for all of it we will swap stuff around. You find that spring pad?
- hfdco4
I sold one set of hubs and backing plates to a guy on the dent forum. I have the complete axle I can take stuff off for you, that is in much better shape. I did get home on "V" day so I am still breathing. I did have a bad week so far health wise though.
FE390PC
FE390PC
- hdman90
Hfdco4!
Wow! What attention to detail. The Highboy I am rebuilding also has the larger hubs, cool to know I'm not the only one dealing with them!
I am very interested to see how your rear leaf hanger flip turns out. I also have a 2wd frame at my disposal, so it may be worth doing the same!
Until we see it complete, keep up the great work!
- hfdco4
Here is how it sits today.
FE390PC
FE390PC
- hfdco4
The biggest change was keep the rear axle centered in the wheel well of the bed. I had marked the frame/wheel center line and reworked the rear drive shaft so the slip joint works within its travel.
FE390PC
FE390PC
- Manny
Looks good and that's interesting on the keeping the axle centered didn't think about that fully. Also i d have two extra spring pads here. Need to keep a spare for good measure?
- Bullitt74
Looks like progress!
